Elite Strap with battery noisy
enricocerica2enricocerica2 Posts: 4
edited November 2020 in Oculus Quest 2 and Quest
I'm using Elite Strap with battery since several hours and find it very comfortable and well balanced. However it makes some noise when moving the head, mainly plastic cracks noise and the wheel used to fix it is also moving making some distracting noise.
Do you have something similar ?
