How to fix bricked oculus sensor
christopherbee39christopherbee39 Posts: 3
So I used the steam vr and oculus firmware update and one of my cv1 sensors just stopped working not detected on my pc and the light dim turns out its bricked any ways I could fix it? Thanks,Chris
Answers
  • RichooalRichooal Posts: 1,964 Valuable Player
    edited November 21
    By definition "bricked" means it can't be fixed.
    If it is fixable it's just broken, temporarily unusable due to software fault etc. So, What is this "steam vr and oculus firmware update" you're referring to? I don't think there is any update combined from Oculus and Steam. Also firmware update are usually required after an Oculus desk top software update.
    Please say exactly what the update(s) was/were and the version numbers. Was it a firmware update for the sensor or the headset? (if it was a firmware update).
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS 1 minor problem
  • christopherbee39christopherbee39 Posts: 3
    It was for both it was a steam vr update and oculus also did an update combined
    If you give no info, no one can help you.
    BTW Software update and firmware are 2 completely different things. I doubt very much that you did a firmware update.
  • izikmorizikmor Posts: 1
    The same exact thing happened to me today. As soon as steam vr did an update one of my oculus rift sensors stopped working, and it has a dim white light
