Following a full charge, my Elite Strap Battery Pack is going down by about 24% a day if left plugged into the Headset, despite a hard turn-off. The Headset stays at 100%. If however the strap is not connected, both batteries stay at 100% until used, so something is draining the strap battery when it is connected.
I wouldn't have thought it to be necessary to have to unplug the strap after each use, so there must be a fault somewhere.
Any ideas would be much appreciated.
0
You also will notice that if both are at 100% and you use your Quest main battery will first unload to 80% till the battery pack will kick in. That's due to its battery management...
https://www.facebook.com/groups/oculusquestgermany/
