I use the charge cable (usb2) that came with my Quest 1 and this work great. Much longer (~3m) than the shorty supplied with the Q2.
It will be fine, a bit overkill an 80 dollar charge cable. The cable can handle 3amps 5 volts.
I already use it for PCVR but sometimes i like to play really chill games or whatch movies on my bed and that cable is really long compared to the one the quest2 came with. Since i really don't know anything about the tech inaide the cable i wanted to make sure I can use it while charging without damaging the tech.
Thanks a lot both @PITTCANNA @TomCgcmfc
Get Help
