I'm trying to setup the Oculus Rift + Touch and the setup doesn't detect the headsets HDMI, but it detects the sensors and headsets USB. I've got a HP Envy 27-Inch All-in-One Computer, Intel Core i7-8700T, NVIDIA GeForce GTX 1050, 16GB RAM, 2TB HDD I followed the guidelines to install AMD Radeon R9 290 but no luck.
Is the graphics card of my Desktop not compatible or is there any other way aside from AMD Radeon? The orange light in the headset works fine.
Kindly confirm if this can be resolved and how? I need Help
I'm having the same problem, but I have a 1660Ti. I've managed to try the headset on another computer with a 1660 super and it works perfectly fine. (The computer is an HP Omen 30L)
Get Help
