No. Maybe make sure to do this on both your Oculus Desktop app and library as well. Of course, not all unknown sources will work unless they are properly installed, setup, and are compatible with you pc.
Maybe try exiting your Oculus desktop app. Then properly shutdown your PC (do not use sleep/hibernate) and startup everything again.
@Slinzen Sounds like you need to contact Oculus Support and start a ticket. Good luck mate.
