Problem with PTC v25 // seems OVRServer and Service are not starting correctly
Hi folks,
all worked fine for me on PTC v24 (using PTC, because of FS2020) till auto-update to PTC v25. After the update process it seems to me that the OVRServer process is crashing continuously. This ends up in a loop where the Oculus-App is restarting over and over again. Anyone else got the same problem or a hint where to look for a solution? Rolling back to stable v23 solved the problem - but for me its not a solution because v23 does not work properly with FS2020.
