Problem Oculus Quest big lag with my Oculus Quest 2 and Radeon 5700 XT graphic card
Thomas_De_Cuinc
Honored Guest
Hello, I have a problem with my new Oculus quest 2 purchased at the last Christmas. With my old Oculus Rift CV1 the games were very fluid with high settings but with the oculus quest 2 and oculus link my games are just unplayable due to heavy lags even if I set the graphic parameters to the minimum. I have got a good config with 32Go RAM an I7 4790K processor and a new Radeon 5700 XT card purchased in october. I have updated my drivers and also try to install older AMD drivers but it don't work. Have you the same problem? Thanks for answer.
Heisenburg1
Honored Guest
Did you try amd drivers 20.9.1?  I had to roll back to it to get my Oculus Quest 2 working properly with link.
I've seen some saying the 20.10.1 driver worked for them, but the newest amd drivers seem to have all kinds of issues with the Quest.
