04-09-2015 05:47 PM
04-10-2015 01:21 PM
If you have a orange light on that means that the system is working and awaiting video signal.
Only a few aplications work in direct mode Asunder works and alone in the rift work on direct hmd display the rest you must run in extended hmd display mode.You change those from oculus config utility under tools section.This is for the latest oculus runtime.
PS: Try the alone in the rift presentation because it's free.
