I install the new runtime V1.3.0 then trying to run the oculus setup but it gives me a error. Is there something I am missing? My pc is more then capable to run the oculus, still i'll give you guys the what i have in my case to help figure out this problem.
When you install the Oculus software, just skip the part that ask for pluging a rift (the assistant only works with CV1 hardware).
The Oculus App and the Oculus Home will have a warning on the top saying that DK2 is not supported, you can just ingore it. In practice everything works. :smile:
CV1+Touch; Running on GTX980 - 4770K - 32GB DDR3
Developer at LIV
