I need some Help, AUDIO ISSUES
WolfoxWolfox Posts: 34
I read post, but can't find a solution,I don't want to use the CV1 headphones, I took them off and Set in the setting to use the Windows Defualt.
But now I don't get audio anymore from the headphones KIngstone Cloud X connected with 3,5mm Jack to the motherboard.
Also with Oculus home switched off or if I go and view a video on the web, there is totally no sound.
On the sound bar where you control the volume is possible to see the green lines moving, but no sound through the headphones.
The RIFT EAR CUPS ARE DISCONNECTED.
Thanks
