OvrPlugin.ipd doesn't work on gear vr — Oculus
Hey guys,
From Unity, it seems that the parameters "Stereo Separation" and Stereo Convergence" don't affect anythings. At least I didn't find the code that change any proprieties in the platform libs.
I tried to use OvrPlugin.ipd but it's doesn't work, always return the default ipd 64mm. it means that on gear vr the sdk lock the ipd? maybe because the hw can't change the ipd of lens?
I have also the same problem with OVRProfile.eyeHeight. I need to change it but I can't find a way
Thanks
    OVRPlugin is not a public API. To scale the IPD, please scale the Camera as a whole by making it the child of a GameObject and setting Transform.localScale on that. The benefit to using scale instead of directly setting IPD is that head motion will match stereo separation, which is important for comfort.
  • tdsgearvr2tdsgearvr2 Posts: 7
    do you have links ore references? how much scale?
    for example, I'd like to reach 40mm, I have to scale the parent x to 0.625? (because the default is 63mm)
    and what about OVRProfile.eyeHeight? to change it I have to scale the parent y?
    Thanks
    Here is the doc.
    The default varies per-user based on their calibration. Try this:
        rig.trackingSpace.localScale = Vector3.one * (0.04f / Vector3.Distance(rig.leftEyeAnchor.position, rig.rightEyeAnchor.position));
    OVRProfile.eyeHeight is currently hard-coded to return an average height across all users. If you want to use another value, set OVRPlayerController.useProfileData = false and then set the Y position of the OVRCameraRig to whatever you want.
    Thanks man.
    the last question, what exactly means eyeDepth, it looks like stereo convergence? and if so how to change it in gear vr.
    There is no stereo convergence setting. The cameras need to point parallel to match the optics of the VR headset. Eye depth is the z distance between the center of head rotation (the base of your neck) and the camera position (your eye). Again, on Gear VR this is hard-coded to an average value for all users.
    Thanks for your great help :)
  • ShawnFeatherlyShawnFeatherly Posts: 9
    This post came up while doing some Googling. I found setting a custom IPD for the Rift to work in Unity 2018.2.0f1 with the follow:
            float myDreamIpd = 0.042f; // enter the IPD in meters
            var leftEye = UnityEngine.XR.InputTracking.GetLocalPosition(UnityEngine.XR.XRNode.LeftEye);
            var rightEye = UnityEngine.XR.InputTracking.GetLocalPosition(UnityEngine.XR.XRNode.RightEye);
            float hardwareIpd = Vector3.Distance(leftEye, rightEye);
            float scale = myDreamIpd / hardwareIpd;
            Camera.main.transform.localScale = new Vector3(scale, 1, 1);
