Empty third sensor position with OVRManager.tracker.GetPose(2)
EmuZeroEmuZero Posts: 29
edited November 2016 in Unity Development
TL;DL: With 3 sensors, OVRManager.tracker.GetPose(id) works OK for the first and second sensors (ids 0 and 1), but returns (0,0,0) for the third sensor (id 2).
Hello!
I'm working on an app that uses each sensor position, and it works correctly for the two first trackers, but not for the third one.
  • OVRManager.tracker.count does return 3.
  • OVRManager.tracker.GetPresent(id) does return true to ids 0, 1 and 2 (and false to id 3, as there's only 3 connected sensors).
  • OVRManager.tracker.GetPoseValid(id) does return true to ids 0, 1 and 2 (and false to id 3).
  • OVRManager.tracker.GetPose(id) returns valid positions and orientations to ids 0 and 1, but empty values for ids 2 and 3 (it should return valid values for id 2).
"Empty values" being position (0, 0, 0) and rotation (0, 180, 0).
Here is an output example:
trackers count: 3<br>------<br>id: 0 | present: True | poseValid: True<br>id: 0 | position: (0.9854, 1.8364, 0.5153)<br>id: 0 | rotation: (15.8191, 233.1839, 1.3493)<br>------<br>id: 1 | present: True | poseValid: True<br>id: 1 | position: (-1.7348, 1.6925, -1.0900)<br>id: 1 | rotation: (359.7148, 67.5559, 0.3881)<br>------<br>id: 2 | present: True | poseValid: True<br>id: 2 | position: (0.0000, 0.0000, 0.0000)<br>id: 2 | rotation: (0.0000, 180.0000, 0.0000)<br>------<br>id: 3 | present: False | poseValid: False<br>id: 3 | position: (0.0000, 0.0000, 0.0000)<br>id: 3 | rotation: (0.0000, 180.0000, 0.0000)<br>
Is this a bug, or am I doing something wrong?
Thank you.
    Third-sensor support has been added to the 1.10 release of the Utilities and the latest releases of Unity.
  • EmuZeroEmuZero Posts: 29
    I'm actually using Oculus Utilities 1.10, but Unity 5.4.2p4. I see they have a 5.4.3 version.
    Whoa, they just released Unity 5.5 a few hours ago. I should've waited just a little more. Thanks!
    The version with the fix is 5.4.3p1. 5.5.0 should also have the fix.
    Awesome, thank you.
