Animation Unreal Engine 4
WsOculusWsOculus Posts: 10
is it possible to scale down main actor with animation?
For example Ant-Man movie by marvel. The protagonist has the view of an ant.
    Moving to Unreal Developer section.
  • tonsta31tonsta31 Posts: 271 Oculus Start Member
    edited February 2017
    IF you want a smooth scale down you can use a timeline and set the location Z axis to the timeline values but bear in mind motion sickness can be caused by manipulating the camera.
    We are now on Patreon! https://www.patreon.com/mgsstudios
    Feel free to have a look around as there are some nice special offfers.
    Owner of MGSStudios
    http://www.mgsstudios.com
  • WsOculusWsOculus Posts: 10
    Yes thanks.
    I used timeline
