Gear VR bottom USB C slot
Rolls085Rolls085 Posts: 3
is it possible to connect latest Gear VR to PC or some controller through the bottom USB slot ? If I connect some flash disc or card reader everything works, but PC and controller did not do anything :(
  • pekayattpekayatt Posts: 133 Oculus Start Member
    I used a DS4 controller AND a Xbox360 controller without any problem using the OTG....
  • Rolls085Rolls085 Posts: 3
    Nice, and which OTG cable are you using ? (or what is your "connection scheme") thanks :smile:
    I am just using the same that came with the Samsung S8. I believe they give this together with the phone to make a backup or transfer from the old phone to the new one.
    Ok, I found new thing - if I connect controler in Oculus system running it shows me that USB is conneted, but if I switch oculus soft. off it doesn´t connect :( I want to use it in application which is not in oculus shop ...
