Ignore Oculus hand shader unit test in git
CHADALAK1CHADALAK1 Posts: 58
Hello Community!
I want to use the built in Avatar hands and hand shaders for a current project, but the problem is if I have the shader included on git and do a unit test via git, the shader makes the unit test hang up for about 40 minutes because it's rebuilding the shader in git (which it should be doing for a project when unit testing). Without the Avatar shaders, it's about 4-5 min.
I was curious if there is a solution to either optimizing the shader/have Unity ignore the shaders when doing a unit test?
  • CHADALAK1CHADALAK1 Posts: 58
    @CHADALAK1
    This is a known issue with Avatars at this time and there is no current fix for accelerating this import.
    Ahh sad day :(. I'll just keep an eye out for a new update of the OVR Avatar shader changes
