Can anybody help me with OVRPLayerController prefab, ( hand anchor) Thanks
I am playing with the OVRPLayerController prefab,
i have attached the GearVrcontroller prefab to the right hand anchor,
and im trying to change the transform of the controller so it aims centrally..
when i change the transform it accepts it, i load up gear vr and then as soon as i move the controller it reverts back to the default place What can i do to get the controller to centre please? I am looking to change the model of the controller to a gun ,
Thanks for taking time out to read this
  • markncolleen1985markncolleen1985 Posts: 12
     Always coincides with the pose of the right hand.
        /// </summary>
        public Transform rightHandAnchor { get; private set; }
    Is there any way of changing this ?
    edited December 2017
    trackerAnchor.localPosition = tracker.position;  Ok i found it any help on how to change the placement of the anchor ?
    anchor.localPosition = Vector3.zero;
    Ok also my question, does the GearVrcontroller have to be anchored to the ovrcamera? or can it be placed elsewhere ?  Thanks
    Bump, how do we break the anchor please?
    bump :)
    Hi, thanks for your reply. I am using unity 2017.2 and utilites 1.20,
    The part im trying to change is:
    The OVRCameraRig script positions all of the anchor objects, based on the name of each object
    I need to change this so i am able to centre the hand anchor for the controller into the middle of the camera, as you know its currently centred to be placed as a (hand) placement. ( so i can aim down down the iron sight ) I need the anchor set at eye level on the camera please
    I have tried to change the transform and overwrite it but no matter what it always defaults back, how can i change the position of the hand ?
    This will help greatly
    Best regards and thanks for the work you guys do here
    Also your picture really makes me smile, good choice lol
    Thank you very much Your a star
