Issue in Unity Social Starter example invitation system
Hi all,
We are working on a multiplayer project for Gear VR, consisting of an environment sharing between two guest, so we just started with the Oculus Social Starter for Unity from the AssetStore.
 The issue we encountered is that the invitation between user A to user B and viceversa works only the first time we install the App, from the second time onwards, the Oculus UI keeps telling the user “Cannot invite this friend”.
This gets fixed only by uninstalling and reinstalling the application, clearing the application data has no effect.
Some data:
  • Environment is Unity 5.5.4f1 with the latest platform SDK update
  • The app is the vanilla AssetStore Oculus Social Starter, we tried also with our main app with the same result
  • We’re using both the white and black GearVR with S6 and S7
  • Tried more or less all kind of connection combinations: same router, different hotspots, 4G connections
Can someone help us ?
Thanks
Alessio
  • a.bottossoa.bottosso Posts: 4
    edited December 2017
    Hi @imperativity,
    Thanks for your reply.
    We fixed that using a custom UI approach instead of the "LaunchInvitableUserFlow()" one..
    Best regards.
    Alessio
