Two questions regarding recording from the Oculus VR VST Plugin (Output Format and some Clicks!)
First of, I just want to mention that I've been having a lot of fun with designing in the Spatializer. I could do it for hours. And support for Reaper has been markedly improved,so thank you! (Though I would be remiss if I didn't mention that it seems to crash occasionally when loading VST3 plugs in the same chain. Not sure where the fault is on that, but FabFilter Pro-Q2 as VST3 doesn't seem to like OVR.)
ANYWAY. Two hopefully super simple questions:
- What B-Format is actually being recorded after I've armed and recorded a file? Wwise wants either FuMa (W, X, Y, Z) or AmbiX/ACN (0,1,2,3). This is my first time working in VR and so I don't have a solid grasp over why one is preferable over the other but I've read that I should stick with FuMa. ¯\_(ツ)_/¯ Either way, I don't know how to check what's being output, or how to set it.
- What reasons might there be for getting momentary/periodic clicks/pops/dropouts in a recording? Surely three instances of the spatializer is not overloading my system or anything, right? Is there a setting somewhere that can be adjusted to help remove this? I've never had buffer issues before, and I've already increased it way past what I've ever increased it to before.
  • chris_bobchris_bob Posts: 7
    Gotcha! Thanks, @imperativity! I'll give that a shot in Reaper and see if your advice here helps. Hadn't seen that before!
    Any word on what format is being output when I'm saving a new file from the plugin?
