[SOLVED] Crash with Unreal Engine 4 Integration 1.24.0
NeontopNeontop Posts: 231 Oculus Start Member
edited March 2018 in Unreal Development
Hello,
I successfully build Unreal Engine in VS but when I try to add  to the Template_Default.umap a Nav Mesh Bounds Volume, I have a crash.
It happens with a blank Blueprint and also a C++ basic code.
Update Visual Studio to latest version
  • NeontopNeontop Posts: 231 Oculus Start Member
    @imperativity
    Thanks for the feedback.I just recreated the project with the standard source distribution of UE 4.19
    And also with
    the source distributions hosted on Oculus’s private GitHub .
    You can see the pics from UE4.19_Oculus and UE4.19_Unreal.
    I have sent to you the the saved/log and a zip of the saved/crashes.
    Thank you.
    @imperativity.
    I have updated Visual Studio to 15.6.4 AND IT WORKS !!!!
    PROBLEM SOLVED.
