Fix for shaky/distorted objects in Right/LeftHandAnchor?
TBA_VRTBA_VR Posts: 4
edited April 2018 in Unity Development
I'm no longer at the PC I use to develop, so I can't provide a picture of my problem. I'm using Unity 2017.4.0, or whatever the most current version is.
So, I've had trouble getting items tracked by the touch controllers to display properly. Using the Unity Utilities 1.19, Oculus Platform SDK 1.19, and Avatar SDK 1.16, I am trying to display the avatar hands to in my scene. Everything works fine at first, but the avatar hands start to shake and become increasingly more shaky as the scene goes on; it almost looks like a mirage as it gets more distorted.
It also does the same for child objects of the Left/RightHandAnchors of the OVRCameraRig prefab. For example, when attaching a cube to the RightHand, I'm able to move it around as normal using the controller. It looks like a normal cube at first, but then starts shaking and become more distorted and mirage-like. I have no idea what might cause this to happen, and I'm so close to having the TouchControllers set-up otherwise.
Answers
  • ProtopottyGamesProtopottyGames Posts: 17 Oculus Start Member
    Do you by any chance have any (non kinematic) rigedbodies attached to your controllers? If so you may be having collider conflicts.
    Also when you say "as the scene goes on" do you mean there are other gameplay element's being introduced in the scene as you play, or do you just mean as time goes on in a blank/static scene?
    Absolutely update your Unity utilities/Oculus sdk stuff as suggested by imperativity.
    Who knows what kind of issues could come about from not being current there.
    One other thing you might check for is if anything in your scene might be falling to infinity. If there's an object with a rigedbody/collider falling through the floor to infinity, it *could* cause this kind of behavior over time as the scene plays.
  • TBA_VRTBA_VR Posts: 4
    edited April 2018
    imperativity said:
    Is there any particular reason you are using such out of date packages in your application? We have newer versions of these integrations that may have addressed issues like this on your downloads page here.
    I had the same problem with both the current version and the older versions. I initially had a problem with a shader being absent from the most recent Avatar SDK. Since I was following a tutorial (I'm a newbie) from around November, I wanted to make sure it wasn't anything with the more recent Oculus and Utilities packages as well.
    I'm using a completely empty scene to test this and get it to work. There are no elements being introduced over time. There are also no rigidbodies attached to any of the controllers in the LocalAvatar object.
    Here is a picture of my scene setup, along with the described phenomenon. This was capture about 30 seconds after starting the scene. This was tested with the most recent versions of Utilities for Unity and Oculus Platform SDK, and Avatar SDK version 1.22.0.
    Oh wow..hm...Yeah never seen anything quite like that before. :sweat_smile:
    Not sure, but it could be a floating point precision issue with animation. Does the issue still occur if you move the GameObject closer to the origin (0,0,0)?
    If this is the case, try setting OVRCameraRig.useFixedUpdateForTracking. That will cause all the XRNodes to update their poses in lock-step with physics and anything else on the FixedUpdate cadence, causing them to judder a little more in rendering, but simulate more smoothly in the physical environment.
  • olej1964olej1964 Posts: 1
    I know it's an old thread. But i have exactly the same problem. running Unity 2019 2.6f1. Shaking so much after some 10 sec. that i can't recognise tha hand or the model im holding.
  • zebcodezebcode Posts: 1
    Same issue here
  • AldeRobergeAldeRoberge Posts: 2
    Same here. No one got it figured out?
  • Ot_FreezeOt_Freeze Posts: 1
    I think I had the same problem and I believe the fix is as simple as putting a plane underneath your character because at the start, your character immediately falls very fast and the farther from the origin, the worse textures get.
  • TheSwanCollectiveTheSwanCollective Posts: 18
    edited March 30
    Yeah that's actually true! This happened to me in the game 'The Under Presents'! I fell through the floor and this weird resolution thing happened to my hands. Kind of mesmerizing effect.
  • CryszCrysz Posts: 1
    For me, it was not checking the IPD in Position Tracking option under the OVRManager in your OVRPlayerController! Once IPD is checked, everything should work properly.
