Oculus Go - Default controller ray and reticle
redwhiteca_serdarredwhiteca_serdar Posts: 16
edited May 2018 in Unity Development
Is there a prefab for that?
I want to replicate the fading of the controller, fading of the ray, the auto-resizing reticle in my app.
  • imperativityimperativity Posts: 3,587 Valuable Player
    In our Oculus Utilities for Unity package this 3d model is automatically generated in scene for you. I believe that is the limit of the prefab at this time and it does not include the ray and auto resizing reticle functionality. We do, however, have blog posts illustrating how to apply this to the hand model for Gear VR, which is 100% the same for incorporating with the Oculus GO.
    See the below blog for an example:
    https://developer.oculus.com/blog/easy-controller-selection/
  • redwhiteca_serdarredwhiteca_serdar Posts: 16
    edited May 2018
    Thank you, I have already implemented the ray and the reticle with some help from those examples.
    The original Oculus implementation though, has such tiny details that it would be nice to have them as prefabs. Like:
    • The reticle scales up / down a little, due to the proximity to a target.
    • The controller model fades out when you move it up above.
    You know, we think many of our clients / users would prefer the exact same UI elements if the app is not a game, just like there is a consistent cursor behaviour in a desktop OS.
  • Barsik_The_CaTBarsik_The_CaT Posts: 8
    @imperativity
    Are there any guides that are valid for current version of Oculus Utilities for Unity? Tried following https://developer.oculus.com/blog/adding-gear-vr-controller-support-to-unitys-ui/, but some assets mentioned there aren't a part of that package anymore. I've mostly figured things but, but I am completely lost how to implement a reticle that will be visible only on canvas
  • behnam-lumbehnam-lum Posts: 3
    You should really consider adding these to your Oculus Utilities if you care about the consistent user experience across applications!
  • morte111morte111 Posts: 6
    edited December 2018
    Test Developing with Rift CV1, I have downloaded and tested some sample scenes in the latest Oculus Integration Utilities v1.31 for Unity - most scenes have something useful to use, even if not everything works, or is incompatible as-is with Unity 2018 (requires some code tweaking for deprecated methods)
    - something of note is the Oculus/Avatar/Samples/SocialStarter/Assets/MainScene, which does the loading of a custom avatar, complete with autofading linerender rays & pointer spheres which match those in the default Oculus Home user interface, however the code which creates those rays and pointers is not externally exposed to developers
    - it appears to be an internal function of the Oculus.Avatar.CAPI class, of which we only can see headers, because it is an API inside the OVRPlugin.
    Unfortunately that does not help developers who need lightweight high performance/low overhead code for mobile platforms, like Gear VR which I am attempting. Importing ONLY the VR subtree hierarchy from this unitypackage works for SOME scenes which have no platform or avatar code dependencies, but if you start using certain prefabs or scripts, a web of cross-dependencies on the AudioManager,Avatar,LipSync,Platform,Spatializer,VoiceMod subtrees will soon emerge, necessitating a monolithic import of bloat, even if you remove the various 'Sample' subtrees.
    As official companion unity packages to the Oculus Integration/Utilities, I have tested the line render technique shown in the Oculus Sample OVR Updated Controller Interaction (separate unitypackage) and certain locomotion scenes in Oculus Sample Framework (separate unitypackage)
    - both also designed for earlier versions of Unity, in order to test locomotion/teleport/rotation as well as UI interaction, but that brought additional complexity because of differing versions of OVR scripts in the sample scene prefabs which are incompatible with the same named scripts in the separate Oculus/VR/Scripts hierarchy.
    Additionally, the Oculus Unity UI interaction for Touch/GearVR/Go/Malibu controllers seems broken when dealing with anything more complex than a toggle, button, input field, or slider bar. (i.e. Things like a Unity UI.DropDown result in reverting to selection via a non-visible Gaze Cursor.)
    There is a user-submitted hack for this here: https://forums.oculusvr.com/developer/discussion/39327/gaze-pointers-drop-down-boxes
    (thx @jhocking !)
    It also bears repeating to say Unity UI Navigation must be disabled on all in-scene UI components to avoid the 'stuck focus' bug, (selects the previous UI element on click rather than the UI element currently being pointed to).
    I will try the hack, and try to use something other than a dropdown or scroll field, but just be aware not everything is integrating well....
