How to know left or right controller?
How do I know if the controller for my Oculus Go is Left or Right handed in Unity? Is there a simple command to put in an if statement like:
if (Controller is left) {
  • imperativityimperativity Posts: 3,587 Valuable Player
    Welcome to the Oculus Developer Forums.
    I would not worry about specifying this in Unity.
    Oculus Go locates the controller relative to the user by using a body model to estimate the controller’s position. Whether the controller is visualized on the left or right side of the body is determined by left-handedness versus right-handedness, which is specified by users during controller pairing.
  • HeyBishopHeyBishop Posts: 16
    Hi @imperativity,
    It's important to me to be able to determine the handedness too.
    For the Oculus Go, I have the following code:
    Debug.Log("Is L connected: " + OVRInput.IsControllerConnected(OVRInput.Controller.LTrackedRemote));
    Debug.Log("Is R connected: " + OVRInput.IsControllerConnected(OVRInput.Controller.RTrackedRemote));
    At runtime (on the device) both lines return: "Is X connected: False".
    So, what am I doing wrong? How does one determine which hand the user is using?
    I got the above code from the following documentation:
    https://developer.oculus.com/documentation/unity/latest/concepts/unity-ovrinput/#unity-ovrinput
    I just checked to see how it's done in the GearVrControllerTest scene provided. It would seem this function doesn't work here either. Was OVRInput.IsControllerConnected(OVRInput.Controller.LTrackedRemote) deprecated?
    edited December 2018
    OMG! I figured it out!
     OVRPlugin.GetDominantHand();
    It's an enum. With it, I created the following script:
    public class UserHandedness : MonoBehaviour
        public static UserHandedness Status { get; set; }
        void Awake()
            if (Status != null && Status != this)
                Destroy(gameObject);
            else
                Status = this;
        public bool IsRightie()
            OVRPlugin.Handedness handedness = OVRPlugin.GetDominantHand();
            if (handedness == OVRPlugin.Handedness.RightHanded)
                return true;
            } else
                return false;
        public bool IsLeftie()
            if (handedness == OVRPlugin.Handedness.LeftHanded)
                return true;
            else
                return false;
    With it, I can do this in any other script:
    if (UserHandedness.Status.IsLeftie())
                Debug.log("You're a southpaw, awesome!");
