Oculus Avatars hands animations on a full body avatar?
mrgreen72mrgreen72 Posts: 683
I’ve implemented a full body avatar using Final IK in my prototype and while the results are beyond my expectations so far, it’s missing hands animations.
So I was wondering if there was a way to use the awesome Oculus Avatar hand animations on a standard humanoid rig?
  • mrgreen72mrgreen72 Posts: 683
    Is there any way to get your hands models and animations?
    I'm probably just dense but everything seems to be "hidden" into external libs. (DLL's)
  • owenwpowenwp Posts: 681 Oculus Start Member
    In the Oculus Unity Sample Package there is a scene where they use the avatar hand animations on a custom mesh. I haven't looked at it closely, but I am guessing you get the bone transforms in a script.
    Found it thanks!
    No idea how I can retarget those animations on the hands of an humanoid rig or if it’s even possible though. I’ll keep digging!
  • baroquedubbaroquedub Posts: 5
    mrgreen72 said:
    Found it thanks!
    A year later and I'm following in your (IK) footsteps :) Did you work out a way of doing this?
    Any help would be much appreciated
  • doukasddoukasd Posts: 3
    Also interested in this. Is there a standard way or is everyone writing their own from scratch?
    Basically the "Custom Hands" demo in the Oculus Unity Integration is using animations made for "hand rigs". Is there a way to use those on a full body avatar?
