Is it OK that SteamVR plugin required (it is enabled by default) to build a project? Previously only Oculus VR plugin was required. With it's disabled there are Gradle errors during project build. Error
I am unsure how your error is related to SteamVR, but the error you're getting may mean you need to link Unreal Engine's AndroidPermission library by adding the following to your .Build.cs:
