Camera fade without Mobile HDR?
VRexVRex Posts: 64
I'm trying to do some camera fades for an Oculus Go project in Unreal 4.20 and am unable to find a good way to do so without enabling Mobile HDR. I imagine that would destroy my framerate. What are the options to replace a camera fade in this case? I would do a UI or transparent animated plane but that seems like it would wreck performance as well. Would love to hear some suggestions. Thanks!
Jesse Kirberger
  • GRADGRGRADGR Posts: 46 Oculus Start Member
    Camera Fade requires HDR, then only efficient way to do this is by creating a "fake" fade widget with full screen size. This can be added to pawn camera or even to a sequence by using events.
  • VRexVRex Posts: 64
    Yeah, that's what I figured. Isn't the transparency going to screw up frame rate though? I'll give it a go. Thanks, GRADGR.
    Jesse Kirberger
  • DizzzieDizzzie Posts: 16 Oculus Start Member
    Did you ever figure this out?
  • christian_svrchristian_svr Posts: 27
    An interesting new feature in Oculus' UE 1.31.0 is color scaling - https://developer.oculus.com/documentation/unreal/latest/concepts/unreal-color-functions/
    If you can update the engine, I'd consider looking into achieving the effect that way.
  • rasamayarasamaya Posts: 13
    This works for nice camera fades while streaming in and out levels. Great idea, thanks! Implemented in a few projects on Quest
