Oculus Rift framerate randomly becomes stuck at 45 or 30 FPS when headset presence changes
Running into an odd problem here with a Unity project. I'm only using 4 ms of CPU per Update and not doing anything taxing on the graphics side. It effortlessly hits 90 FPS... most of the time.
Sometimes (about 3/20 times) when I remove the headset and put it back on the framerate drops to 45 or 30 FPS. The problem usually goes away if I poke my finger in front of the head presence sensor a couple times. According to the Unity profiler this problem is all vsync, which makes me suspect something odd is happening on the Rift's side of things.
Any ideas on how to fix this?
Using Unity 2018.2.14 with oculus SDK 1.33.0.
