Jerky Motion When Capturing VR Gameplay in 60 Hz
Capturing VR gameplay for a trailer in 60 Hz when Unity is locked to 90 Hz (Rift) results in jerky motion because of frame skips.
How do you address this?
  • PAaltoPAalto Posts: 74 Oculus Start Member
    Yeah, that seems to be a problem. My plan is to create a separate non-VR scene in Unity, where I have full control of camera movement, and then run that scene at 60 Hz. But as I said, that is only a plan at this point, as I am still not at the stage in my game development where I could get good enough footage for my trailer. If someone has better ideas, speak up!
  • nat42nat42 Posts: 15
    Dumb idea (and not even looking at the Rift myself): can you record at the full frame rate and reduce the frame rate in your video editor (at the very least this should be able to blend frames rather then dropping them, but good video editors can probably do more intellient interpolation)
