UE4.21 "Warning: Changing the spatialization algorithm on a playing sound is not supported" ?
Does anyone know what this warning means and how to fix it? Using the Oculus UE4.21 with Auido 1.34. Everything is working fine I just dislike warnings.
I get it whenever my sound cue plays.
  • PetrozaPetroza Posts: 149 Oculus Staff
    edited February 2019
    Hi James,
    I haven't seen that warning but I found it by searching through the code. It looks like that will only happen if you're using the old XAudio based audio system. If possible I recommend using the new UE4 AudioMixer, it has more features and better plugin support. It should also fix that warning you're getting.
    To enable AudioMixer add the following to /Config/Windows/WindowsEngine.ini
    <div>[Audio]
    <span style="background-color: transparent; color: inherit; font-size: inherit; font-family: Helvetica, Arial, sans-serif;">AudioDeviceModuleName=AudioMixerXAudio2</span></div>
  • jamesoloughlinjamesoloughlin Posts: 12
    Petroza said:
    Hi James,
    <div>[Audio]
    That fixed it! Thanks classic case of someone (me) ignoring the documentation.
