Rotating object with Gear/Go controller touchpad (SOLVED)
AnneLantingAnneLanting Posts: 13
edited March 4 in Unity Development
Hello,
In Unity 2017.4 i had a script to rotate in object with the touchpad of the controller, Gear-vr and Go. I started a new project in Unity 2018.3 (oculus integration 1.34), and used te same script. But it doesn't work anymore. This is the script:
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
public class KE_ObjectRotation : MonoBehaviour
    public GameObject ObjectToRotate;
    Vector3 objRotation = new Vector3(0f, 0f, 0f);
    public float objRotationSpeed = 60f;
    // Start is called before the first frame update
    void Start()
    // Update is called once per frame
    void Update()
        float TrackpadX = Input.GetAxis("Oculus_GearVr_DpadX");
        if (TrackpadX != 0f)
            objRotation.y += TrackpadX * Time.deltaTime * objRotationSpeed;
            ObjectToRotate.transform.rotation = Quaternion.Euler(objRotation);
Anyone understanding the problem?
Anne
  • radicalappdevradicalappdev Posts: 11
    I'm just guessing, but I think it has to do with the way you are getting the X axis of the trackpad. Perhaps that was an old way of doing that before Oculus Go? Or maybe you have some input manager that uses that value?
    When I want to get the values from the trackpad I do this:
    private Vector2 touchpad;
    void Update()
    {     touchpad = OVRInput.Get(OVRInput.Axis2D.PrimaryTouchpad);     var xValue = touchpad.x; // Get the x axis of the touchpad
  • AnneLantingAnneLanting Posts: 13
    @ Radicalappdev: thanks for te suggestion, works fine !! Thats perhaps a better, future-proof, solution. Turns out i made a mistake in the code GearVr should be GearVR, then that works to.
    Anne
