Oculus Audio SDK Unreal Integration
alexandra_verzi
Honored Guest
Hello,
I was very hyped by the technology presented for the new audio SDK and wanted to use it in Unreal.
I installed the engine from the Oculus branch on github. (so it's 4.21 + 1.34)
But it seems like its not working ... At least the propagation part. The functions are actually there, I can tag the meshes and add a OculusAudioGeometry and OculusAudioMaterial, but then it doesnt do anything to the sound.
So I wanted to know, am I doing something horribly wrong or is it just not implemented yet?
Also is it easy to integrate / use in Unity ? I could consider switching then. For me the most important are reflections (especially, early reflections).
thanks, cheers
0 REPLIES 0
