Oculus Go Controller Setup Problem
mazuquelimazuqueli Posts: 2
edited April 16 in Unreal Development
Hi! I've configured the oculus go controller following a tutorial on you tube (epic and others) but when I pack to the Oculus Go the controller is not visible.
I'm using unreal, can someone help me?
Here is my setup, I'm using unreal engine 4.22
  • aussieburgerVRaussieburgerVR Posts: 236 Oculus Start Member
    You need to show your motioncontroller detail panel
  • mazuquelimazuqueli Posts: 2
    I've tryed a lot of settings for the motion controller (left, right, any hand) none worked.
