Quality Settings are being set to "Fastest" despite a default.
mogacreativemogacreative Posts: 11
Developing in Unity 2018.4LTS and using Oculus Integration 1.37
Related to this thread. Link
I have noticed on builds that the quality setting are being overriden to the 'Fastest' state. Below is the Rift settings I am using, set to the default.
The problem persists whether or not "use Required Project Settings" is toggled. Any thought?
  • mogacreativemogacreative Posts: 11
    Here is the Project Setting window during build:
    arg nvm just had to drag the 'Rift' levels to the Top
  • el_jergasel_jergas Posts: 19
    Can't you just uncheck the quality levels that you don't want?
