When I connect my Quest to my PC (Win10) and tell the Quest to allow access, the Quest does not appear as a Device/Drive in the 'This PC' panel, but it's listed as a device in the 'Device and Printers' panel. I've included a couple screenshots of the issue. I'm missing something here but not sure what it is. Any help would be great. Thanks.
After trying a number of solutions that did not work I found the solution. In the device manager uninstall the "Oculus Composite ADB Interface" and check the delete drivers option. Then disconnect and reconnect the quest to the PC. Hope that helps someone.
