Unity Build and Android device is not responding with Quest
davedevdavedev Posts: 5
I am on macOS 10.13.16 using Unity 2019.1.8f1 and get an "Android device <device num> is not responding" error. See attached. Developer mode is enabled on the Quest. Any ideas how to fix? I've tried a new cable because it initially wasn't finding the device at all.
  • davedevdavedev Posts: 5
    Figured it out myself. For the first build on the Quest I initially missed the confirm connection dialog on the Quest. Noticed it, confirmed, and the build now loads.
  • DinnoOculusDinnoOculus Posts: 3
    I have no confirm connection dialog on Quest... even after re-plug the cable. what can I do?
  • AGTDigitalAGTDigital Posts: 19
    Hello,
    Is your headset in developer mode ?
  • brianellissoundbrianellissound Posts: 1
    Hello! I'm having a similar issue. Device is in developer mode, I've tried unplug and replugging in the cable, as well as restarting both the computer and the device. What other options do I have?
