How to achieve antiAliasing in VR (Oculus Rift S and Quest)
My problem is how can I get rid of jagged edges in my scene, especially with UI elements.
HDRP is not supported for oculus quest apk. I have tried the following things but neither solves my problem:
  1. quality setting anti Aliasing set tp 2X multi-sampling
  2. CenterEyeAnchor Camera's rendering path to forward, turn on MSAA.
Here is the script i have attached in the scene:
using UnityEngine;
using UnityEngine.XR;
public class VRRenderScale : MonoBehaviour {
    void Start () {
        XRSettings.eyeTextureResolutionScale = 1.5f;
  • WeitinWeitin Posts: 44
    For UI elements, you can try to tweak the CanvasScaler values or play around with the mip maps on your textures
    Wei Tin Yuen, VR Developer  B)
    Toronto, Canada
    http://tinforge.com/
  • DarkTableDarkTable Posts: 27
    edited October 2019
    There are a lot of issues using the Lightweight Render Pipeline (aka Universal Render Pipeline or LWRP) on the Quest, but one thing that definitely works is MSAA. I haven't tried using `eyeTextureResolutionScale`, so I can't guarantee it's compatible with that, but you can get readable UI text.
    (Edit: This pic was taken on a Quest. The scene is using 4x MSAA.)
