oculus go device not listed in adb.
Muthuprakash
Honored Guest
I'm installing app from unity through build and run options ,the app builds and runs in go successfull shows in consle while we saw the app in unknown sources it's not there inside the go headset.The device is not shown in adb list also is there any way to resolve this issue.
vrinter
Explorer
Hey, check this thread with many more people with the issue: https://forums.oculusvr.com/developer/discussion/81029/adb-device-list-empty
vikneshtk
Honored Guest
@Muthuprakash You have to check your mobile app to which you have linked the device. Enable developer mode again. Restart the GO and try again. It happens to me in the quest. What I suspected was the automatic update of the oculus software in these devices.
