Not sure why OVRGrabber script is not working correctly with customhands??
Saeed786129Saeed786129 Posts: 3
The problem is that the hands are offset way ahead of the player and tracking is with opposite hands
I am using customhand left and right.
both parent transform and player are set to OVRCameraRig and OVRPlayerController respectively.
Best Answer
  • starmind001starmind001 Posts: 7
    Accepted Answer
    Did you by chance reset the position after parenting? Also did you child the hands to the hand anchors? For example, custom hand to be a child of left hand anchors?? This worked for me.
Answers
