IMPORTANT:
SkinnedMeshRenderer material from OVRHand prefab is overwritten every frame
jormajejormaje Posts: 11
I want to change the main material from the Skinned Mesh Renderer component (OVRHand prefab).
In Unity Editor this change remains but in build it only remains for 1 frame and it's replaced by the initial material on the next frame.
Is it possible to change hand material in realtime?
Is this a known issue?
  • jormajejormaje Posts: 11
    Ok I found a solution by turning the private variable _originalMaterial from OVRMeshRenderer into a public one.
    It is set on Initialize() and it was being reset every time you are not making the system gesture
