Oculus subsystem and dedicated server connection issue
EanirEanir Posts: 14 Oculus Start Member
edited May 2020 in Unreal Development
My game has an open world running on a dedicated server where clients can join and leave any time. It also has PvP sessions using Oculus' matchmaking service. To use the matchmaking service I have to use the OculusNetConnection net driver. If I set this up in DefaultEngine.ini, then clients can host/join games, but they are not able to connect to the dedicated server due to 'Connection TIMED OUT'. If I roll back to the default UE4 netdriver, then clients can join to the dedicated server, but obviously they can't make sessions. How can I connect to the dedicated server using OculusNetConnection? Here is the DefaultEngine.ini:
[OnlineSubsystem]
DefaultPlatformService=Oculus
bHasVoiceEnabled=true
[OnlineSubsystemOculus]
bEnabled=true
OculusAppId=**********************
RiftAppID=**********************
[Voice]
bEnabled=true
[/Script/OnlineSubsystemOculus.OculusNetDriver]
ServerTravelPause=4.0
[/Script/Engine.GameEngine]
+NetDriverDefinitions=(DefName="GameNetDriver",DriverClassName="/Script/OnlineSubsystemOculus.OculusNetDriver",DriverClassNameFallback="/Script/OnlineSubsystemUtils.IpNetDriver")
NetConnectionClassName="/Script/OnlineSubsystemOculus.OculusNetConnection"
[/Script/Engine.NetDriver]
AllowPeerConnections=False
AllowPeerVoice=False
ConnectionTimeout=60.0
InitialConnectTimeout=60.0
KeepAliveTime=0.2
MaxClientRate=15000
MaxInternetClientRate=10000
RelevantTimeout=5.0
SpawnPrioritySeconds=1.0
NetServerMaxTickRate=30
MaxPortCountToTry=512
  • EanirEanir Posts: 14 Oculus Start Member
    Any thoughts on this? Did anyone manage to run both dedicated servers and matchmaking? Is it possible to run a dedicated server with OculusNetConnection? Or is it possible to run matchmaking sessions with the default UnetConnection? Should I use different net drivers somehow?
  • twistedpixel_bobtwistedpixel_bob Posts: 38
    did you get this figured out?
