Help Uploading APK to Release Channel
tspree15tspree15 Posts: 33 Oculus Start Member
I'm trying to upload my apk and I'm getting an error, I have no idea why.
It's telling me it's the wrong format, but as far as I can tell it's not.
Can anyone shed some light on the problem?  Thank you
Flight.apk: Incorrect file format. Please select a file with one of the following types: application/vnd.android.package-archive, .apk
  • mediaupmediaup Posts: 4
    Me too, can't solve it, trying to upload it since the day before yesterday. Any luck? Answers?
    When trying to upload it with OVR Platform from Unity it says - Can't fetch initial upload config.
  • ruud3DVruud3DV Posts: 22 Oculus Start Member
    edited November 22
    Same error here, but managed to upload to a channel using the command line ovr-platform-util:
    using:
    ovr-platform-util upload-mobile-build --app_id <app ID> --app_secret <app secret> --apk <path to apk> --channel <channelname>
    using:
    When I run the ovr-platform-util it just shows black windows for a sec and it's gone. They said that the Unity ovr integration 18 has built-in util in Oculus-Platform but when I try to upload it from there it just shows the error: Can't fetch initial upload config
    I managed to get command up and running but now this error:
    Logs are written to: C:\Users\media\AppData\Local\Temp\oc_cli_3337373606296486_2020-11-23T15-08-13-055Z.log
    ERROR: APK not found: F:\DESK_NOVO\CUBEroll_APK_FINAL\CUBEroll.apk
