Hi there,
I was wondering if anyone has the issue I'm running into recently with the OSP Spatializer aax plugin:
I have 4 aux buses, each with an OSP Spatializer (mono to stereo) insert attached. I then create an audio track (channel number doesn't seem to make a difference) that sends to each of these buses at unity gain. Now I want to be able to record audio into the audio track while those plugins are active. However right when I arm the audio track for recording (or input monitoring, since I'm using non-HD Pro Tools), the entire application crashes and I get an Avid crash log report.
After tinkering a little, it seems like I can do this just fine if I have only one instance of the plugin in my session. It's right when I add the second instance and arm a track for recording that the program crashes. '
Anyone else run into this / have any advice?
Thanks!
I'm running version 1.20 of the aax plugin on (non-HD) Pro Tools 11.3.1 using a 64 bit Windows 10 machine.
