I am currently trying the Oculus Spatializer Unity Plugin, and have a few questions regarding the following 2 test cases, which have the test results deviated from my expected results. Is it by design or is there something wrong in my settings?
Thanks.
========== Background Information:
Windows 10 Version 1803 (OS Build 17134.590)
Unity 2018.2.20f1
Oculus Spatializer Unity Plugin v1.34.0 (latest version) (* same happens in v1.29.0)
Preparations:
Download and extract the attached file "OculusSpatializerTest.zip".
Create a new Unity project, import "OculusSpatializerTest.unitypackage".
Open "SampleScene".
From Edit > Project Settings > Audio, change "Spatializer Plugin" value to "OculusSpatializer".
From Edit > Project Settings > Player, expand "XR Settings" and check "Virtual Reality Supported".
[Case 1]: Volume attenuation with distance using OCULUS ATTENUATION
Setting:
From "ONSP Audio Source" component in "Audio" GameObject, Enable "OCULUS ATTENUATION"
Test Procedure:
Start the scene
Press <Space> key and listen to the sound. Notice the volume of the sound
Change the Minimum range in "ONSP Audio Source" from 10 to 9, press <Space> key again and listen to the sound
Test Result:
the volume of the sound drops drastically
Expected Result:
the volume drops by a reasonable amount by a 1m distance
[Case 2]: Volume attenuation with distance using Unity default method (Not using OCULUS ATTENUATION)
Setting:
From "ONSP Audio Source" component in "Audio" GameObject, Disable "OCULUS ATTENUATION"
Test Procedure:
Start the scene
Press <Space> key and listen to the sound, let the sound fade out completely and press <Space> key again, notice the volume
Press <Space> key and while the sound is still playing, press <Space> key again and listen to the sound
Test Result:
the volume of the sound changes when a sound is currently playing / not playing
If "ONSP Audio Source" component is disabled, the volume remains the same
Expected Result:
the volume remains the same whether or not another sound is currently playing
