Which spatialized audio solution should I use for Oculus Quest using Unity?
DarkTable
Level 7
So far I've tried ONSPPropagationGeometry/ONSPPropagationMaterial combination. It's in beta, partially broken, and had severe performance issues in a small test situation (small room with furniture, one static sound source, two moving sound sources).
I tried the OculusSpatializerUnity script that's supposed to dynamically resize the "shoebox", but the AudioRaycast method never gets called, so the shoebox remains at the default size of 8,3,5.
And I tried the OculusSpatializerReflection mixer group effect. This would require setting up snapshots for every space and transitioning between them. It currently seems the most functional, but would require a lot of manual setup.
Or is there another solution that people are using?
p.s. I'm using this asset store project as my test environment:
https://assetstore.unity.com/packages/essentials/tutorial-projects/foundations-of-audio-183075
3 REPLIES 3
DarkTable
Level 7
I don't want to be the kind of person who goes to Atlanta and raves about Pepsi, but I just tried out Steam Audio and it performs pretty well on Quest 2. I haven't gotten baked reverb working yet, but the basic moving sound sources with 3D positioning, attenuation and occlusion work well.
DarkTable
Level 7
FYI: Just noticed Steam Audio updated to version 4.0.0. last week, with some new features for Android. Haven't had a chance to try it out though.
SimonFireproof
DarkTable, thanks for replying to your own post. Very helpful! It's a shame Oculus seem to have stopped developing their solution but Steam Audio looks good, I'm going to check it out.
