Head avatars not loading or white default heads [Solved]
Deebrol
Hello!
I'm trying to launch the AvatarGallery scene in Unity 2019.4.14f1 with the oculus integration version 23.1.0 and the OVRPlugin version 1.55.1 (same problem with other oculus integration and OVRPlugin versions)
When I run the APK in Quest whit CombinedMesh = true, heads doesn't load and I have the following error:
Hair Mismatching Resolutions: DiffuseTextures 1024 (ID: 1708191947127680157) vs 2048 (ID: 0) Ensure you are using ASTC texture compression on Android or turn off CombineMeshes
at OvrAvatarMaterialManager.ValidateTextures (ovrAvatarPBSMaterialState[] materialStates) [0x00000] in <00000000000000000000000000000000>:0
at OvrAvatarSkinnedMeshPBSV2RenderComponent.Initialize (System.IntPtr renderPart, ovrAvatarRenderPart_SkinnedMeshRenderPBS_V2 skinnedMeshRender, OvrAvatarMaterialManager materialManager, System.Int32 thirdPersonLayer, System.Int32 firstPersonLayer, System.Boolean combinedMesh, ovrAvatarAssetLevelOfDetail lod, System.Boolean assignExpressiveParams, OvrAvatar avatar, System.Boolean isControllerModel) [0x00000] in <00000000000000000000000000000000>:0
at OvrAvatar.AddSkinnedMeshRenderPBSV2Component (System.IntPtr renderPart, UnityEngine.GameObject go, ovrAvatarRenderPart_SkinnedMeshRenderPBS_V2 skinnedMeshRenderPBSV2, System.Boolean isBodyPartZero, System.Boolean isControllerModel) [
If I change CombinedMesh to false, then heads load but all of them are white:
And I have a spatializer error, but I don't think that is the problem here:
Unable to find AudioPluginOculusSpatializer
DllNotFoundException: Unable to load DLL 'AudioPluginOculusSpatializer': The specified module could not be found.
at ONSPAudioSource.OSP_SetGlobalVoiceLimit (System.Int32 VoiceLimit) [0x00000] in <00000000000000000000000000000000>:0
(Filename: currently not available on il2cpp Line: -1)
I have ASTC, OpenGLES3, and the ids in the settings.
I've tried several things and I don't know what else do so I apreciate any kind of help.
Thank you in advance and hace a nice day.
Deebrol
Finally solved!
It was a silly mistake by our side. We forgot to activate the Avatars service in the "Data Use Checkup" in our app.
Also remember to use a rift app id to launch tests in the editor.
VRJohnny
I have done all of this and they are still not loading. Does the app have to actually be published, or should it work as long as I have a working app lab ID? I have avatars activated in AppLab, It is passing the entitlement check and it is fetching/setting the avatar ID before I enable the LocalAvatar object. I don't know what the problem could be.
