Showing results forย
Search instead forย
Did you mean:ย
Echo VR: How to fix "Echo Vr Disconnected From Lobby Due To Timeout" bug?
Solar-Flare
Every time I try to join a lobby or a game, it works fine for the first three minutes, five if I'm lucky. After those minutes, everybody in the lobby or game freezes in place and I'm stuck in time basically until the game closes and I'm brought to the main menu of the game. Every other game I play though Oculus works fine, it is just this one.
Solar-Flare
LZoltowski
Volunteer Moderator
Volunteer Moderator
I am merging this into a single thread,
You might get better support with Echo VR in the Echo Discord channel.
https://discordapp.com/invite/bPB7v8d
Be kind to one another ๐Ÿ™‚
