Problem with the sound of Lone Echo
BloodScar36
Hey guys. I have a sound problem with Lone Echo, because there is no sound. not even voices. I've reinstalled the game but it didn't work, my oculus software is freshly installed. Other VR games work fine, and the Oculus VR Screen has also sound.
7 REPLIES 7
Hey there! We hate to hear that your device doesn't have audio in the game. It's so important in gameplay. Let's help you get back in the game!
We do appreciate you troubleshooting before reaching out to us. Can you please submit a bug report? We have linked the appropriate steps for you HERE
We also suggest you reach out to Support HERE for further assistance and one on one troubleshooting. We look forward to hearing from you!
Hello OculusSupport. I'm using the original Rift Headset, your troubleshooting guide to submit a bug doesn't work, because I can't see these options in my interface.
Are you able do do this on the mobile app on the phone?
I did the bug report on the phone. I hope it's not confusing, that I make a bug report for the PC game, not a mobile app.
TomCgcmfc
Level 15
I audio is fine with all other PCVR games then it should be fine with Lone Echo (1 or 2).  Maybe check and adjust in-game audio settings and see if this helps.
You might also want to try going into your oculus desktop pc app device settings and mirror audio to your PC to see if it's actually sending out audio to begin with.
Also, check your win10 sound settings control panel and check that your headset and disable any enhancements and set your audio output to CD or DVD quality.  Otherwise, contact oculus support I guess.
In the ingame audio settings you can only change the volume, it was at maximum.
I can't mirror the sound because my Rift headset is broken. I only use my normal Headset for sound, which worked fine until now.
@BloodScar36  Try the desktop app device option to mirror anyway.  That’s what I needed to use when my rift cv1 audio broke down.  I also used the OTT audio switching options.
