Is Meta Avatars compatible with Photon Fusion?
Phandolina
Are you using Meta Avatars and Photon Fusion? I have seen sample projects using Photon Pun, but none that use Fusion. I have tried using the docs and adding Meta Avatars to my existing Fusion project, but everything stops compiling once I add the Oculus Integration Package. If you have samples or insights, it would be a huge help.
Thanks!
0 REPLIES 0
