3D printable sensor mount hobby project
caseydvorak
Hey all!
I'm one of the folks at
Oculus who has been working on Oculus tracking and roomscale support.  When
I was experimenting with different setups, I decided to start up a bit of a hobby project to create a few mounts I could use at my setup at home.
I got into 3D printing
about a year ago, and have been having a lot of fun creating some custom items
like this.  Note, these aren't Oculus products or endorsed as official
Oculus mounts, but I figured if people in the community wanted to give a shot
at printing them and adding them to their setup it could be a help.  3D printing can be difficult if you don’t have a lot of experience, so in many cases you’re better off buying official tripod mounts.  That said if you’re up to the challenge feel free to try printing these and/or modify them for your own use.  These are the items attached:
Sensor-holders
holder-corner-slim.stl - Slim version of corner sensor mount
holder-corner-standard.stl - Full rectangular version of corner sensor
mount
holder-flat-slim.stl - Slim version of flat sensor mount, for
mounting directly on a flat wall
holder-flat-standard.stl - Full rectangular version of the flat mount
Cord-guides (to keep the sensor cord against the
wall)
cordguide-corner-slim.stl - Guide which uses one screw to press the cord
against the corner of your wall
cordguide-corner-standard.stl - Guide which uses two screws to press the cord
cordguide-flat-standard.stl - Flat guide to press your cable against a flat
wall
In case you want to try
printing, I used these print settings on my personal machine:
Material: ABS (though PLA or other materials may work)
Infill 20%
Top/bottom/side layers: 4
Speed 40mm/s
Have fun!
P.S. I ended up designing these for #2 Phillips 1" 2.54cm drywall screws.  You should be able to pick them up at a local hardware store if you don't have compatible screws already.
29 REPLIES 29
dengel72
Nice work!
FrozenPea
Level 13
Great design! I'll have to give them a go!
Check out my Medium Sculpts:
https://forums.oculus.com/community/discussion/49696/frozenpeas-sketchbook
Youtube Channel: https://www.youtube.com/c/FrozenPeaSculpts
Griff0x
printed and using, excellent work.
Thank You.
The_Hardboiled_
Will definitely try this out. Thank you for uploading the files!
Shadow_Fury
That's awesome, thank you.
Excuse my ignorance, but I don't see the link to download the parts blueprints
cybereality
Level 16
Look at the bottom of the post, there are 2 zip files attached.
twisteklabs
Level 7
CPU: Intel i5-4690K Mobo: ASUS Z97-AR Ram: 8GB 1600MHz Graphics Card: EVGA GTX 1080 SC
kogermax
#twisteklabs
what design did you use?
god_alom
Can I use really strong adhesive tape?
