05-23-2016 12:22 AM
05-23-2016 05:06 AM
05-23-2016 05:17 AM
Shadowmask72 said:
Canned air is good apparently because there can be specks of dust which when wiped with a cloth can scratch the lenses. Blowing away the dust before you wipe seems prudent. I think the recommendation is air - moisture - cloth.
05-23-2016 05:31 AM
05-23-2016 05:40 AM
Lemming1970 said:
The only issue I could see is blowing small water particles(the misting) into the head set may cause long term issues. It would of course not remove finger/ eye lash marks off the lenses. Which I would have thought was more of an issue than dust!
05-23-2016 08:52 AM
05-23-2016 08:58 AM
Skiwee said:
I'd recommend having a special micro-fiber cloth that you only use for the lenses and store it in a container, that's what I do (have glasses as well). Canned air is a rather aggressive way of removing a little statically charged dust. Also I'd think you'd just be blowing more dust into the headset.
If your getting scratches from a mirco-fiber you need to wash it cause it's full of dirt (don't leave it on your desk).
05-23-2016 09:34 AM
05-23-2016 09:43 AM
Trytiped said:
@mambo1888 I was using compressed air but I have a better recommendation then having to waste your money refueling compressed air. This lens pen has an amazing brush for dusting off the lenses without scratching them http://www.amazon.com/gp/aw/d/B00006JN3G/ref=mp_s_a_1_2?qid=1464020894&sr=8-2&pi=AC_SX236_SY340_FMwe...
It comes with a lens cleaner on the other end but doesnt seem to do the trick in actually cleaning off the smudges so for cleaning I would stick to a microfiber cloth.
For a high quality microfiber cloth I recommend looking into magicfiber also on amazon it does an amazing job cleaning the lenses.
05-23-2016 09:46 AM
